trans cooler
Old Jan 2, 2006 | 04:36 PM
quontush's Avatar
quontush is an unknown quantity at this point
Default trans cooler
Im thinking about getting a transmission cooler, anyone know were i could get one that is for a blazer?
Old Jan 2, 2006 | 04:51 PM
Default RE: trans cooler
You aren't going to find one that will be a direct fit. What you'll find are the universal fits. The size of the cooler will depend on your intentions with the vehicle. For heavy towing, a larger cooler would be better. You can go too large if the cooler does not have it's own way of metering the flow through it's body.
I am partial to the stacked plate coolers and B&M makes a very nice one:
B&M SuperCooler 7-1/2"x11" - SummitRacing.com
This is practically identical to the one that I have installed in my Bravada. I purchased one from Advanced Auto under the Imperial (Hayden) brand name, but had to purchase additional fittings so as to not cut the transmission lines. If you don't car about the tranny lines, then the kits from Autozone or Advanced will work nicely and can be purchased for slightly less than the B&M cooler.
Good Luck!
Oh, fyi, you need to tie the cooler into the upper line off on the passenger side of the radiator.
Old Jan 3, 2006 | 11:38 PM
quontush's Avatar
Thanks for your help
Old Jan 4, 2006 | 09:35 AM
Not a problem man! I'd also like to note that for every 10*F drop in transmission temperature, you extend its life in high heat applications - (ie. towing, stop-n-go, hills) by 50%. The transmission oil cooler in the radiator can only cool down to around the temp of the coolant in the engine (195*F with a stock t-stat).
Here's a chart, kind of hard to objectively draw conclusions due to its non-uniform scale on the life (miles) axis, but it still gives you a good idea of what not to do to a tranny:
[IMG]local://upfiles/667/6216521F53914D65A644AC584635DC06.jpg[/IMG]
Old Jan 14, 2006 | 10:43 PM
ivannj's Avatar
ivannj is an unknown quantity at this point
I think it might be better putting the trans cooler connected to the bootom fitting on the radiator as it say so on the B&M directions. I would go with the B&M buddy very nice and has everything to install and no cutting.
Old Jan 14, 2006 | 10:48 PM
The B&M, with its temperature dependant flow paths would work equally as well in both places. Go for the bottom one if you think you need to, but it's a PITA. The upper one will do MORE cooling than what you'll ever need unless you are doing A LOT of heavy towing...
dunontme
Dec 15, 2009 03:18 PM
95blazer8620
Apr 6, 2007 04:16 PM
Jetfixer
Jul 11, 2006 05:02 AM
ivannj
Jan 16, 2006 04:17 PM
