Vin X vs. Vin W
Old Apr 18, 2007 | 11:34 PM
BlazerSS's Avatar
BlazerSS is an unknown quantity at this point
Default Vin X vs. Vin W
Swartlkk and LastCoupe and any other GM/Blazer experts.
I have heard various answers and would like to hear both of your expertise on what the difference between the vin X and vin W engines is to make the modest hp/torque difference.
(T Series) X=180/245 W=190/250
(S Series )X=175/240 W=180/240
Of course, everyone else is also welcome to provide some helpon the topic.And article links, etc. always help!
I heard it was a bigger Y-pipe in the VIN W then I hear other things about engine internals. Does anyone know. Is there a difference between 2wd vs. 4wd output? I would like to clarify this once and for all.
thanks guys.
Needles
Old Apr 19, 2007 | 07:54 AM
Default RE: Vin X vs. Vin W
You ask and you shall received:
ORIGINAL: Tink over at s-series.org
VIN X, RPO LF6:
Central Sequential Fuel Injection (CSFI), Sequential Fuel Injection (SFI).Manufactured from 1996 to 1999. CSFI uses six individual injectors and a fuel pressure regulator that pulses fuel through six orifices through flexible nylon tubes. These tubes run to poppet valves at the intake ports. Manifold setup is similar to TBI, except it has one bore and one throttle blade. Air filter box is located behind driver?s side headlight.
175hp, 240ft/lbs (2wd pickups), 180hp, 245ft/lbs (4x4 pickups)
VIN W, RPO L35:
Central Sequential Fuel Injection (CSFI), Sequential Fuel Injection (SFI). Manufactured from 1996 to 2003. This engine is similar to the VIN X, RPO LF6 except for increased hp and torque. The only likely difference is computer programming.
180hp, 245ft/lbs (2wd pickups), 190hp, 250ft/lbs (Blazers and 4x4s)
Old Apr 20, 2007 | 06:30 PM
BlazerSS's Avatar
I am confused now because I have a 2005 Blazer 2WD 5-Speed VIN 'X'. So are my power ratings till 190hp and 250lbs?
thanks
Needles
Old Apr 20, 2007 | 07:00 PM
BlazerSS's Avatar
My car engine specs say Manufactured August 2004
Vortec 4300 4.3L SFI V-6 (LU3)
(M50) 466 New Venture MG-5 Tranny
Z85 sporty/firm suspension
Old Apr 21, 2007 | 03:44 PM
The LU3 had some slight differences to the L35, but I believe it retained the same power output.
93S10TahoeLT
Apr 5, 2013 06:59 PM
Kevin.N.Odom
Jan 24, 2010 11:29 AM
SlydinClyde
Oct 18, 2009 08:14 PM
sander
Nov 10, 2006 02:47 AM
chach3835
Engine & Internal
Feb 9, 2006 05:51 PM
