Whats everyones running temp or the coolant/engine in the 4.3?
#41
what temperature thermostat did you put in it?
#42
Mine has run a tick higher then quarter since I got it. Changed the T-stat and didnt change. I did notice the other day that it did go up to the half way mark for a few seconds then dropped back to quarter. Im going to change the coolant temp sensor and see if it makes a difference. My other car's temp guage was doing the same thing. Changed the temp sensor and it fixed the problem.
#43
Mine sits on the line in the middle of the 100-210 marks. If its hot it goes up one of the little marks. But then comes right back to the quarter tank mark.
I wish my scan tool would read the Chevy. It refuses to read it. It didnt like my 95 Blazer either.
#44
so our trucks are suppose to be running around 200 to 210 right? i havnt done anything but put an alum. rad. in my truck and since then, she has been running at the 1/4 make. is this bc of the new rad and would a new therm fix this?
#45
My 1995 S10 Blazer runs at 210
#46
just curious, what would the temperature be at that first quarter mark? anyone know?
#47
It all depends on the stated temperatures at the extent of the gauge. Most temperature gauges are a uniform scale between their indicated values. In the case of the '95-'97 dash, the temperature displayed goes from 100 to 210 so, at the 1/2 way mark between these two values, the temperature should be somewhere near 155. Confirmation with a scan tool would be required if you really want to know what it is.
#48
#49
my 1996 runs at 210 everyday of the year.
#50
195-200 daily driving
220 offroad,or pulling a dodge outta mud hole. made it work today
