Whats everyones running temp or the coolant/engine in the 4.3?
Old 05-04-2010 | 03:22 PM
Phil's Avatar
Is this a good guide?
http://www.ehow.com/how_2152965_lowe...tomobiles.html
Thanks for all the help Kyle.
  #62
Old 05-04-2010 | 03:36 PM
I'm not a fan of scrubbing radiators & condensers. It is just too easy to bend the fins. A good hose stream will provide the necessary action to loosen debris so long as you let the cleaner do the work of softening the debris. When you are all said and done, you should be able to spray water through the radiator, through the condenser, and out the front enough to still be some what of a stream when you are all said and done.
I say to spray back through the radiator back of the radiator towards the front because that is the most effective means of freeing the junk from the fins. It went in from the front and you are just trying to push it back through from where it entered.
I find it easiest to remove the radiator top shroud, the fan, and the bottom shroud to really make sure that everything gets cleaned properly.
NO POWER WASHERS HERE EITHER unless you really know what you are doing or are good with a radiator comb!
  #63
Old 05-04-2010 | 03:50 PM
Phil's Avatar
Awesome, thanks again!
  #64
Old 05-06-2010 | 04:45 PM
Phil's Avatar
Sorry to double post like this, but I was wondering if engine degreaser is a good cleanser for this? Going to give this a go today or tomorrow.
  #65
Old 05-06-2010 | 05:23 PM
Phil, it's not considered a double post if it's been 24hrs
Engine degreaser will likely work. It'll have a lot of solvents in it and it shouldn't hurt anything that's there. I wouldn't let it get on the paint of the vehicle in its concentrated form.
  #66
Old 05-06-2010 | 06:23 PM
Phil's Avatar
Okay cool, I was debating between that and my Meguair's foaming rim cleaner.
  #67
Old 07-09-2010 | 08:29 PM
rbrace's Avatar
rbrace is on a distinguished road
2001 blazer 4.3 4wd standard my temp gauge is always hugging 200
  #68
Old 07-12-2010 | 04:00 AM
David Hineline's Avatar
David Hineline is an unknown quantity at this point
Give men an idiot light, and until it comes on men are happy, give them a gauge and they will worry about it to no end.
  #69
Old 08-08-2010 | 05:25 PM
Chuk Rhodes's Avatar
Chuk Rhodes is on a distinguished road
In the service manual for testing the temp sensor, it says "When fully warmed, ECT sensor should reflect a temperature of at least 185 degrees F". Presumably thats whats required to get the engine in Closed Loop mode. If it does run cooler, you could trick the sensor with a resistor, getting cooler temps and closed loop mode, I wonder how that effects the engine?
  #70
Old 08-09-2010 | 01:25 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
i forgot, what is closed loop and open loop mode?
Quick Reply: Whats everyones running temp or the coolant/engine in the 4.3?
