$10,000 question
Old Sep 20, 2013 | 08:02 PM
coalblack6's Avatar
coalblack6 is on a distinguished road
Exclamation $10,000 question
l have a 1994 4.3 cpi 4x4 l have put new timing chain,iac,tps,dizzy,wires,spider,egr,.it will run great if I unplug the alternator but if l plug it back up it will die and l can crank it back up but will not run cuts off like it runs out of gas ready to have big fire with it help please what can it be
Old Sep 20, 2013 | 10:04 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Have you taken the alternator in for testing? I'd guess at the alternator as the problem though. I'm betting if you check the +12V at the PCM with the alternator plugged in and the key in the 'on' position, you'll have a low voltage.
Old Sep 21, 2013 | 05:44 AM
coalblack6's Avatar
yes l took it and had it checked.they checked it three times showed good.driving me crazy
kiwiblazer
Dec 22, 2009 05:19 PM
BlazeringSaddles
Dec 5, 2009 09:46 PM
lionel2
Apr 30, 2007 09:31 AM
jamie333
Nov 8, 2006 03:47 PM
2001blazer
Apr 28, 2006 04:27 AM
