'00 ZR2 1st Gear Issues
Old Sep 11, 2015 | 10:04 PM
Matt 4.3 TBI's Avatar
Matt 4.3 TBI is on a distinguished road
Default '00 ZR2 1st Gear Issues
This problem has been occurring intermittently for the past two years, never consistently enough for a shop to successfully diagnose it.
Randomly the truck will start out in 2nd gear with the gear selector in D. Manually shifting to '1' does not shift it into 1st. When it starts in second if I stay heavy on the gas I feel something akin to a misfire and the engine bogs (which I am assuming is torque management kicking in) about a solid second before it shifts 2-3. 3-4 shift is normal and the TCC locks up in 4th.
Just as randomly it will find 1st again and operate normally. This hasn't happened in the past two or three months but occurred at least a dozen times this morning and afternoon. During the last 30 minutes of my evening commute the issue had disappeared.
The trans fluid is red and smells normal. I last had the fluid and filter changed last spring at which time both shift solenoids were changed in an attempt to address this issue.
Is this a PCM issue?
Old Sep 12, 2015 | 03:15 PM
newguy's Avatar
hmm tough one, I have the same truck with no issues. could be something as simple as a dirty electrical connection on the tranny itself. Start simple, search the net
Old Sep 21, 2015 | 04:15 PM
I changed the ignition switch about a week ago, thus far I haven't experienced this problem. It's always hard to tell when an intermittent problem is fixed so I'm keeping my fingers crossed!
Bratrod
Jul 26, 2015 02:12 PM
Falconator
Apr 19, 2009 07:15 PM
fiszot
Nov 10, 2008 06:03 PM
fun2b1
Apr 5, 2008 08:43 AM
chigger
Dec 31, 2007 12:50 PM
