04 Blazer 4x4 RPM's
Old Feb 26, 2011 | 04:36 PM
bella313's Avatar
bella313 is on a distinguished road
Default 04 Blazer 4x4 RPM's
What are the normal RPM ratios when shifting? I think my RPM's are running higher than usual when tranny shifts.
Idles at 500, then seems to run up to 1500 for 1st and just past 2200 for 2nd. After 2nd gear, it seems to reduce back to 1200-1500. For some reason, it seems to be running higher and sounding different than normal.
Any suggestions?
Old Feb 26, 2011 | 07:25 PM
rriddle3's Avatar
Of course shifting rpm will be determined by how much right foot you put into it, but those numbers look pretty normal.
*EDIT* After watching my tach, it appears that all my upshifts occur between 1900 and 2500 rpm depending on the gear, so yours may be shifting at low rpm for some reason.
Old Feb 28, 2011 | 05:27 AM
bella313's Avatar
Thanks....
I need to take it on the highway to see where it runs at high speed. City speeds of 35-45 has the RPM's at around 1200-1500 steady, then dropping as I brake.
fbaker25
Nov 15, 2019 03:41 PM
fbaker25
Oct 14, 2012 11:49 AM
dutchman31
May 4, 2011 09:09 PM
monette999
Nov 4, 2010 02:15 AM
rastaskater
Feb 29, 2008 07:08 AM
