100K Miles Tune-up
Old Jan 17, 2009 | 04:16 PM
tmurph01's Avatar
tmurph01 is an unknown quantity at this point
Default 100K Miles Tune-up
My Jimmy is getting close to hitting the 100K Mile mark. What kind of maintenance, if any,should be done?
Jimmy is a 2001 4-door, 4 wheel drive
Thanks guys!
Old Jan 17, 2009 | 06:43 PM
NVANZEE's Avatar
Default RE: 100K Miles Tune-up
i also would like to know. anything besides plugs, wires, fuel filter, air filter, oil change, coolant flush?
Old Jan 17, 2009 | 07:07 PM
rriddle3's Avatar
Go to this site, register your VIN, and you can download a pdf of the owner's manual with recommended maintenanceschedules in it.
Old Jan 17, 2009 | 07:52 PM
Maybe check out the related threads below as well.
Old Jan 17, 2009 | 10:20 PM
Jazon's Avatar
Jazon is an unknown quantity at this point
You may also want to consider checking all of your sensors.
Old Jan 17, 2009 | 11:40 PM
c5ce's Avatar
c5ce is an unknown quantity at this point
I'm planning on a tune up this spring. Plugs, wires, cap, etc. I'll use AC/Delcoirridium plugs. They are recommended for LSx engines, so they should do the trick well in a 4.3L.
I use GM parts, usually GM Performance parts, and I buy from GM Parts House at http://www.gmpartshouse.com
I use sythetic oil and change every 5k miles. I also change the air filter at every oil change.
Old Jan 19, 2009 | 12:07 PM
Hanr3's Avatar
Replace your vacuum hoses, especially if they turn your hands black when you touch them.
run_girl
Jun 5, 2013 11:41 PM
allman
May 31, 2013 08:32 PM
Ronald
Apr 2, 2008 05:24 PM
shinclyde
Engine & Internal
May 26, 2006 11:31 PM
