1989 4.3 tbi swaped into 1995 4.3 cpi's place
Old Nov 17, 2009 | 07:02 PM
chrisw1022's Avatar
chrisw1022 is on a distinguished road
Default 1989 4.3 tbi swaped into 1995 4.3 cpi's place
ok first off thanks for lookin and helpin a young do it myselfer out ive had blazers my whole life but never swaped like this befor and i got both these givin to me so i figured why not ive got a 1989 4.3 tbi engine and trans i want to put into a 1995 cpi's place i have the donor 1989 blazer i was wanting any tips or tricks on wiring the 89's harness into the plug from the 95's engine so it will plug into the firewall for the fuse block......the plugs are dif from the 89's harness to the 95's fire wall plug and theres more plugs on the 95 help would be awsome
Old Nov 17, 2009 | 08:57 PM
It all depends on what PCM/ECU setup your '95 has. If you have the OBD1.5 or OBD2 setups, it is going to be a nightmare. If it is straight up OBD1, it might not be too bad. Your transmission is all manual control (no PCM intervention) so you'll have to use the older ECU...
You'll want to get the wiring diagrams for both trucks and see what wiring you can weed out. It is not going to be a fun swap... That is for sure.
Old Nov 17, 2009 | 09:11 PM
chrisw1022's Avatar
its a vortec so im guessin odb2 how would i find out??....and would stickn a intake and carb on it make it any easier???
Old Nov 17, 2009 | 09:14 PM
That would do away with most all of the electronics. You would also have to put in an HEI distributor. I am not sure how happy the rest of the electronics in the truck would be, but that would be easier than trying to drop to TBI.
You may want to check with your local laws though. This type of swap may be illegal. You should find out before putting a lot of work into it.
Old Nov 17, 2009 | 09:22 PM
chrisw1022's Avatar
im in ohio you can drive a car with vise grips as a steering wheel here haha i wouldnt even bother with the swap but the trans and engine is shot in the 95 but the body is choice and i didnt pay a dime for it and the 89 the body is toast a arms rotted frame tweaked but its the snappiest tbi ive drove and i got it dirt cheap so i figured id make one good fromn the both hmmmm over my head a bit but ill figure out somethin....thanks for the input
Old Nov 17, 2009 | 09:34 PM
It would probably be less of a hassle to rebuild the motor and find a suitable trans.
If you had a 93 or 94, I would say that it wouldn't be too much trouble, but 95 is a bastard year.
If you have the OBD2 connector under the dash, you could either have the OBD1.5 setup or the full OBD2 setup.
techboy89
15
Dec 21, 2017 04:20 PM
shelbysguns
Feb 21, 2011 11:23 PM
sirwilliamwagner
Jan 29, 2011 11:10 PM
paulsavage33
May 4, 2010 07:04 PM
jackstraw278
Nov 7, 2007 08:29 AM
