1992 engine into 1996.
Hi, I ordered a GM rebuilt engine at my local shop to be installed on my truck. The engine that arrived is part # L4392W that says it's for a 1992 4.3L Blazer W code. I have a 1996 S10 Blazer LS 4.3L W code 4x4 with california emissions. The shop says it will fit and that it will work. Will there be any problems, or will it work fine so I can straighten things out? Thanks.
Did you get a short block, long block, or complete engine? If its a short or long block everything will probably work A OK.
It's a long block with the heads on it. From the little info I've found, I think that the heads are different and that the timing cover is not the same, but I'm not sure.
hope the oil pan will fit in it.. i had a 93 motor out of a 2wd that wouldn't work in my 4wd
randrm
01-25-2011 02:51 PM
poepoe624
01-10-2010 11:48 AM
Boiler_81
12-02-2008 10:04 AM
