1995 blazer 4.3 now power
i have a 1995 blazer 4.3 yesturday i would turn the key and nothing would happen after tryin a few times the truck would start. Then at the end of the day i started the truck drove out of the parking lot and the truck went completly dead no power to anything any ideas ??
did it start back up after? when you say you, "turned the key and nothing happened", do you mean that absolutely nothing lit up? like no dash lights (warning lights)?
if that's the case, it sounds like you have some serious fault in your main power feed.
question, where is the ECM on your truck?
blazer no power
no it didnt start up it has no power at all to anything when it died all power flashed then that was it and it been dead ever since the battery has power but nothings working
Check your connections @ the battery and alternator and make sure no wires or srews came loose!
^^^Check the connections like said above.
Have you replaced any thing lately??? Battery, Alternator, Starter???
You could check to make sure you have power at the bus bar on the drivers side fender, by the vacuum pod (looks like a round ball) it is covered with a plastic cover that is held in place with a plastic nut. Remove this cover and check voltage should be hot all the time (battery voltage).
Check the pink wires.
If no voltage....look on the back of the alternator. There is a wire (pink) that supplies voltage to this bus bar you should also have voltage there, if not then you probably have a blown in-line fuse coming off the battery.
If you have voltage at the bus bar aka "distribution bar" then it could be a faulty ignition switch.
RodneyB
07-23-2015 09:48 PM
repomonster
10-22-2014 01:33 PM
jrgnsnmk
01-13-2011 11:49 AM
the wood
10-29-2005 12:48 PM
