1995 chevy balzer 4x4 4 door trying to find fuel schrader valve
Cant seem to start my balzer
cant find fuel pump fuse under the drivers side dash
Have a After market alarm system cant find alarm fuel cutoff
Can someone please direct me in the right path to fix this
also having problems with ac need vacum line diagram or something, blows out window and floor on all controls no dash air
The fuel pressure test port is located off the back side of the intake plenum near the brake booster and just below the seam between the upper intake and lower intake halves.
As far as a vacuum line diagram, maybe check Autozone.com. They sometimes have these things.
There is a fuel pump relay in your glovebox. Behind the access panel.
Is it getting gas? Is it getting spark? That will help narrow it down.
dj00140
16
Sep 13, 2011 06:47 PM
Tortex53
Feb 21, 2011 05:48 PM
