1995 S10 Tranny - what's this hold for?
Old May 15, 2012 | 09:13 PM
Nitro37's Avatar
Nitro37 is on a distinguished road
Default 1995 S10 Tranny - what's this hold for?
More than a drop per second of trans fluid comes out this hole (pix attched), so I can't drive far. When I stop, it continues to leak for maybe a minute. This hole is in the casting or bell housing (?) at the rear of the engine, just in front of the exhaust crossover. I'm not about to repair the transmission--short of replace the pan gasket, which seems to be intact--but what's this leak mean? Am I in big trouble, as in Big Bucks? The Blazer is definitely not a collectable vehicle, plus pushing 190,000 miles. This is 2nd transmission.
Attached Thumbnails 1995 S10 Tranny - what's this hold for?-blackberry-misc-5-2012-015.jpg   1995 S10 Tranny - what's this hold for?-blackberry-misc-5-2012-012.jpg
Old May 16, 2012 | 06:56 PM
Jase1979's Avatar
Jase1979 is on a distinguished road
Your transmission pump seal or torque converter seal are leaking, trans. needs to be removed for these seals to be repaired. The hole is likely there to allow condensation build up to escape, otherwise the cover would fill with water.
Old May 16, 2012 | 07:34 PM
chris015's Avatar
if you are SURE its the trans fluid then its the front seal leaking. You have to remove the transmission to change it. pull the trans,slide off the convertor and grab a pair of pliers and pry out the seal,knock in the new one,replace.
It sucks.
Old May 17, 2012 | 10:24 AM
Nitro37's Avatar
Default Thanks, Jase and Chris
This is probably not the way to get back to you guys, but I just want to pass on a quick "Thanks" for your responses. Too bad you didn't have better news. I'm not physically up for the repair work so ol' Little Red will have to be put out to pasture...seems like the transmission shops/owners I know are such notorius liars, I'd rather just quit trying to keep the car on the road.
Best of luck to All.
Darryl
Old May 17, 2012 | 12:20 PM
xgiovannix12's Avatar
you can keep the car on the road just keep an eye on the fluid levels
Mines been leaking for 2 years now .... But i really need to fix it cause it gets annoying checking it twice a week
Even tho i loose a quart every 3 or 4 weeks
Old May 17, 2012 | 03:53 PM
Jase1979's Avatar
Before you put it in the pasture try throwing in some of the lucas trans additive to see if it stops or slows the leak, It worked on my last truck for almost 3 months
Old May 17, 2012 | 06:57 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Most likely the bushing is worn out in the pump. Mine was when I had mine out for rebuild. So I'm sure a leaking seal was next to happen. It's unfortunate you cannot do it yourself.
CraigSnedeker
Feb 1, 2010 09:16 PM
offskooring
Jan 11, 2009 07:33 PM
kerander
May 18, 2008 04:18 AM
oldchevron62
Nov 24, 2006 03:05 AM
strongboy2005
Feb 20, 2006 02:36 PM
