1997 Blazer transmission completely gone??
Old Apr 20, 2009 | 12:15 AM
troyky29's Avatar
troyky29 is an unknown quantity at this point
Default 1997 Blazer transmission completely gone??
I'm sure I already know the answer, but figure I would make sure. I have a 97 Blazer 4x4 with 190,000 miles. When I bought it, it had 174000, and the transmission had just been rebuilt. Since getting it I had the shift solenoids replaced by a shop. Yesterday I drove it down the road and when I stopped and took off I was getting a slight grinding noise and some jerking. It then took off and drove fine, When I stopped again, I got the same thing, but this time it would not move. All gears were lost including reverse. After checking the fluid which was fine, I tried it again and it moved a couple feet then lost everything again. I know the transmission is probably shot, but not being a mechanic, I am just trying to confirm this. Never seen one go that fast.
Old Apr 20, 2009 | 11:26 AM
Have these problems gotten worse since your August 2008 post discussing issues with your transmission?
If so, then I would say a complete rebuild is in order.
Old Apr 20, 2009 | 02:29 PM
troyky29's Avatar
The problem before was a shift solenoid had both replaced at a shop and it has been fine since then.
Old Apr 20, 2009 | 03:20 PM
Was your current problem an instantaneous one or did it slowly get worse?
Old Apr 22, 2009 | 06:13 AM
troyky29's Avatar
It just went out all at once. No warning signs until a few minutes before. When I stopped and took off, I got a clunk and a jerk. When I stopped again it did not take back off.
Old Apr 22, 2009 | 09:22 AM
Definitely sounds like one of the hard parts in the transmission went.
Halen
Oct 3, 2014 07:03 PM
Vigo
Jan 7, 2011 12:09 PM
gotti3586
Oct 16, 2009 08:50 PM
bkabina
Feb 25, 2007 08:41 AM
strongboy2005
Engine & Internal
Feb 9, 2006 06:12 PM
