1997 blazer vaccum leak
Old Oct 25, 2009 | 10:59 AM
lac8362's Avatar
lac8362 is on a distinguished road
Cool 1997 blazer vaccum leak
i have a 1997 blazer with a vacuum leak on top of the of the motor where the wires from the harness go into the plastic intake right in back of the gas lines. i pulled the top of the wire cap off and wiggled the blue nipple caps around and the leak almost goes away is there a gasket to replace at this point under these 2 nipple caps there is alot of small wires there, i have failed emmisions has code Po507 idle above range /vacuum leak
Old Nov 5, 2009 | 12:35 PM
lac8362's Avatar
Default help need sticker
need some insight to take this apart and fix
Old Nov 2, 2011 | 08:17 AM
lac8362's Avatar
bought gasket set oval rubber gasket was snapped in half from previous installation all fixed cost about 50 bucks for gasket set
PhantomZ
Aug 19, 2015 12:22 PM
scotties19681968@hotmail.com
Oct 8, 2013 04:40 AM
warthogdriver
Mar 4, 2010 03:50 PM
gscrippler
Jul 28, 2008 04:00 PM
shanes
May 5, 2006 01:23 PM
