1998 chevrolet Blazer 4X4 4.3 to 4.8L engine swap
Hello, I have a chance to buy a 1998 4X4 Blazer with a blown 4.3. I already have a wrecked 1999 Siveraldo 2 wheel drive with a 4.8 engine that runs good. Both have a 4L60E Tranny. Will the 4.8 bolt up to the blazer's transmission? Or do I need to let this one buy pass? Thanks Randy028
You are going to go through heck to get the Gen3 engine into your truck. They recently installed a 5.3L v8 into a Blazer on one of Spike's Powerblock shows and even those guys said they would never attempt it again. They had to custom modify the oil pan, the heater box, and the motor mounts to get it to fit properly.
Don't go by the spike swap alone. They didn't inform scott (the expert they called in) of all the details. They just sent him a far off shot of the truck and asked if he would help. They then ordered parts for a 2wd and not a 4x4 like they needed. Then they cut corners left and right. Scott has complained on more than one forum how they hacked that thing together. The reason they haven't done a follow up on it cause theey had to pull it and redo it. The oil pan leaked cause they welded it and didn't clean it right (even after they showed scott on tv disapproving it) and the tuner they used against scotts wishes messed the ecm all up. The heater box and mounts had to be modded cause they ordered the wrong part and due to scott taking off from work and production timing didn't have time to reoder the correct parts.
Granted its not as easy as the old sbc to put in but nothing like the joke they made it. Go at it with research, correct info, and correct parts it can and has been done cleanly. A 98 will be an easier swap than when I put the ls1 in my 87.
If you notice, all the mods involve their sponsors and their sponsors see the goober crackers as the target market.
So on that Tbird they spent a lot of cash, building a whole new powertrain and got a car that probably couldnt break into the twelves.
IIRC, they actually took out the IRS and put in a live axle... for no freaking reason. Since IRS Mk's run 10's just fine with upgrades to the stock irs.
Daddydustin
06-09-2012 08:30 PM
crazy zx
09-28-2009 07:04 AM
