1999 chevy blazer won't run
Old Jan 19, 2009 | 07:30 AM
  #31
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Default RE: 1999 chevy blazer wont run
I'll have to look when I get home if no one else chimes in because I cannot remember for the life of me.
Old Jan 19, 2009 | 07:47 AM
  #32
Range (10-104 kPa [1.45-15.08psi]) : The Manifold Absolute Pressure (MAP) sensor measures the change in intake manifold pressure caused by engine load and engine speed changes. During WOT, MAP will be maximum. During decel, vacuum will be high in the intake and MAP will be displayed at its minimum pressure.
Range (0.0-5.0 Volts) : The MAP sensor produces a low signal voltage when the manifold pressure is low. A low MAP voltage indicates a high vacuum in the intake manifold. The MAP sensor produces a high signal voltage when the manifold pressure is high. A high MAP voltage indicates a low vacuum in the intake manifold. With the ignition ON and the engine OFF, the manifold pressure equals the ambient atmospheric pressure. This will produce a relatively high MAP signal voltage. The VCM uses this information as an indication of the vehicles altitude. This parameter is referred to as the BARO.
You can test by back probing the sensor return to the PCM (LT Green wire on a 2000) with the positive lead of a DVM and the negative lead to ground or back probing through the Black wire. Test it both ways to see if you may have a grounding problem. You should also test the third wire which should be the +5V reference that the sensor uses.
m3dragon
Feb 24, 2015 10:04 AM
abuchanan0708
Nov 25, 2011 08:18 PM
jerry osaer
Sep 8, 2010 08:03 PM
pbrew
Jun 1, 2010 12:36 AM
midnightbluS10
Aug 7, 2009 03:07 PM
