2000 Blazer 4x4 Trans Replacment
Old Jan 10, 2018 | 11:34 AM
jamesramey89's Avatar
jamesramey89 is on a distinguished road
Post 2000 Blazer 4x4 Trans Replacment
Can anyone tell me what gaskets/filters/fluids i might need when i replace my transmission?
Old Jan 10, 2018 | 04:59 PM
chevyriders's Avatar
Assuming it is an auto- There is a gasket in between the tranny and t-case that will need to be replaced. I always replace the tranny oil filter/pan gasket at the same time as well. Make sure you find out if you have a deep or shallow tranny oil pan, and get the correct corresponding filter. dextron 3 automatic transmission fluid is what you will want.
It would also be a good time to check the fluid level in your t-case, and top it off if needed. If you have a 3 button(np233) it also uses dextron 3. if it's a 4 button(np236) you need a special gm blue autotrac fluid.
Old Jan 10, 2018 | 05:00 PM
awesome thank you for the information!
Rol
Dec 18, 2010 02:48 PM
toxikchevy
Engine & Internal
Jan 26, 2010 04:27 PM
big-country
Suspension Tech
Dec 4, 2009 09:05 PM
jstutzman
Nov 24, 2009 10:38 PM
rob1621
Feb 29, 2008 08:15 PM
