2000 Jimmy 4x4 hard shifts
Old Oct 10, 2012 | 07:50 PM
tmnc78's Avatar
tmnc78 is on a distinguished road
Default 2000 Jimmy 4x4 hard shifts
Ok, so I have a very hard shift from park to drive and reverse but mostly goes away once it gets to normal operating temp. Also a hard 1-2 shift all the time and feels sluggish in 1st gear. So far I've tried a new tps, a new epc solenoid, cleaned maf sensor and changed the tranny fluid and filter. Nothing has helped so far. What should I look into next? A whole new valve body?
Old Oct 10, 2012 | 10:02 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Heard of the issue before
I would suspect a failing acumlating Piston in the valve body
Old Oct 11, 2012 | 02:01 PM
tmnc78's Avatar
Thanks for the reply, i was thinking about that myself. I wish i had put a drain plug on the pan when i had it off.
Old Oct 29, 2012 | 06:03 PM
tmnc78's Avatar
Today i changed the 1-2 accumulator and put in a sonnax pinless forward accumulator piston. The 1-2 shift feels better but still clunks into drive. Do i need to unhook the battery to reset the computer?
dmc919
Mar 23, 2011 10:00 AM
TheNasty0ne
Dec 17, 2010 09:59 PM
Dfretty
Sep 9, 2010 09:54 PM
hubert hefner
May 12, 2010 05:55 PM
bearsfangb1
Mar 24, 2010 07:04 AM
