2001 gmc jimmy transmission compatability
Old Sep 3, 2013 | 09:17 AM
old 5k0ol's Avatar
old 5k0ol is on a distinguished road
Default 2001 gmc jimmy transmission compatability
will a 4l60e transmission from a 2000 blazer 2wd work on my 2001 jimmy 4wd?
Old Sep 5, 2013 | 07:47 PM
Blazer Steve's Avatar
Blazer Steve is on a distinguished road
First off does it have the removable bellhousing. If so yes.
You'll need to tear down half of the transmission. Remove valve body. Remove pump.
Pull out the input drum,and reverse drum remove band, remove and replace snapring. remove sunshell
Then tap out output shaft on 4x4 model. Two wheel model remove tail housing.
You'll need a ATSG manual . Inspect 3-4 clutch pack as it sees lot of off on action. Or pay a trans shop to tear down and inspect clutch packs as you'll be over half way to a complete tear down.
It takes me half a day to do it. $400 later.
JackedJimmy
Jul 16, 2014 08:55 PM
bdude273
Nov 22, 2013 08:30 PM
Kulsmash
Mar 29, 2013 01:48 PM
londonmazda
Oct 19, 2010 02:15 AM
drobinson633
Jun 22, 2010 08:54 PM
