2002 blazer Valve tap---- intake leak
Old Feb 7, 2010 | 02:54 PM
gunnysarge's Avatar
gunnysarge is on a distinguished road
Exclamation 2002 blazer Valve tap---- intake leak
my wifes 2002 blazer just started what sounds like a valve tap. 1) can the lifters be adj.? she uses 5w-30 oil could 10w -30 help with this?
Also while looking this over I noticed coolant coming from the front corner of the intake, she told me shes had to add coolant a few times . Could one be causing the other????? I don't see water/coolant in the oil ..
Any help???
Old Feb 7, 2010 | 03:41 PM
I have seen a few collapsed lifters and even a few bad cams in these engines. The rocker arms are not adjustable, but it wouldn't hurt to pop off the valve cover and check the torque on the retaining bolts.
I would get that LIM gasket fixed up sooner rather than later. It won't get better.
Old Feb 7, 2010 | 04:40 PM
gunnysarge's Avatar
Thumbs up valve tap
Thanks Ill look at the bolts and Ill get the Intake manifold Gasket fixed ASAP...
Old Feb 15, 2010 | 11:29 PM
TsMachine's Avatar
TsMachine is on a distinguished road
Feeling your pain Gunny, just had the same thing happen here on the drivers side so started riping into it today. So far no fun.....
stinz
May 19, 2013 10:31 PM
milehigh
Aug 30, 2012 01:36 PM
HorrorxHotel
Jul 10, 2010 08:22 PM
bigpar Blazin
Apr 15, 2007 04:08 PM
Lucky614
Jan 31, 2006 10:23 AM
