2002 manual transmission omg it wont come off...
Old Jan 16, 2011 | 11:21 AM
suprman1169's Avatar
suprman1169 is on a distinguished road
Default 2002 manual transmission omg it wont come off...
i am in the process of taking my tranny off of my 02 blazer... i have taken off the y pipe, starter, drive shaft, and all the 15m bolts around the tranny to the engine... idk what else i have to take off i started pulling the tranny i got the bottom of it to come off like a half an inch but the top looks like something is holding it idk... i dont know a whole lot about this type of stuf but im very mechanicly inclined and low on money so im trying to do this myself i idk what else to do on it any help would be nice... the reason im taking the tranny off is to change the slave cylinder....
Old Jan 16, 2011 | 01:08 PM
ok so noone has replied with any help yet but i have still been working on this i have the tranny coming off all the way around except for the top left side by the oil filter something is holding it and idk what it is do i have to take off the oilfilter???
Old Jan 17, 2011 | 09:40 AM
Frog's Avatar
Frog is on a distinguished road
Did you remove the line going to the slave cylinder??
Old Jan 30, 2011 | 03:10 PM
ctyler's Avatar
ctyler is on a distinguished road
I just pulled my tranny(automatic) yesterday and it was a pain cause it was stuck.
Its been almost 20 years since doing this stuff. I had pulled and rebuild 6 or so turbo 350's and 400's and the tranny always about fell off.
No amount of yanking, wiggle etc.. would budge it. I sprayed the pins with PB blaster, may have helped idk. Ended up using a chisel in several spots to gently get a gap started. Then a large screwdriver gently tapping to pry it loose. Had to do one side then the other a bunch of times. The pins were rusty and made it super tight.
This was on 1999 4wd blazer.
Just a note...there are a couple places on the oil pan you don't dare pry against or you might break it.
1990blackgt
Jan 12, 2010 07:09 PM
EuroGoldLS
Detailing
Oct 6, 2007 10:43 AM
TheBrettster
Sep 5, 2007 06:34 PM
Jlee031
Detailing
Jan 7, 2007 10:47 PM
nofear17bmx
15
Dec 20, 2006 03:14 AM
