2002 zr2 only shifts manually-no reverse
Old 07-27-2017, 10:40 AM
oldirtyboe's Avatar
oldirtyboe is on a distinguished road
Thanks! The help is appreciated.
Old 08-02-2017, 03:30 PM
oldirtyboe's Avatar
So far the 1-2 solenoid was stuck and the 2-3 valve was hanging up.
Old 08-03-2017, 07:48 AM
oldirtyboe's Avatar
Pulled valve body. Unstuck the 2-3 valve. Reinstalled and we now have all forward gears (even a tire chirp) but no reverse.
Old 08-03-2017, 08:10 AM
Transman304's Avatar
Does it shift by itself or are you shifting it manually? Are the 3 8mm headed bolts that hold the plate behind VB tight?
Old 08-03-2017, 09:45 AM
oldirtyboe's Avatar
It shifts on it's own from regular drive. Up shifts and down shifts. It used to attempt to pull itself in reverse but now it does not move at all in reverse. All bolts are tight. I did see that there is a chance that one of the longer bolts may be in the wrong spot and that will prevent it from engaging reverse.
mypile
07-26-2017 08:47 AM
ws6power1
08-09-2014 09:10 PM
KidBlazer
03-25-2013 07:19 PM
AndrewO1991
11-02-2012 10:25 PM
98BlazerLS
01-06-2005 10:37 PM
Quick Reply: 2002 zr2 only shifts manually-no reverse
