2K Blazer - Shifter on column goes through all gear, trans still in park...
Old Jun 20, 2011 | 03:53 PM
pgerenday's Avatar
pgerenday is on a distinguished road
Question 2K Blazer - Shifter on column goes through all gear, trans still in park...
First question on the forum for me, though I've searched the forums for the solution to ALL the standard 2nd Gen S-Blazer problems.
Started the Blazer up, pulled the column shifter into reverse and nothing happened. In fact, the shifter slides smoothly through all gears like it's actually not connected to anything at all. The digital indicator on the dash shows it in PRND2L as I go through each gear, so I take that as some sort of positive electronics sign...
Is it as simple as a cable/linkage that I can re-attach on either end? Or is there something electronic in the mix that I'll have to troubleshoot?
Thanks in advance for any help you can provide.
matthewp
Apr 4, 2021 09:16 PM
jasedude
Nov 24, 2010 04:03 PM
blazpsz
Nov 12, 2010 08:38 AM
rbcar1
Dec 13, 2009 10:20 AM
blazerscooby
Jun 30, 2006 07:24 PM
