4.3 feels gutless to drive
Old Dec 31, 2018 | 10:51 PM
MadMerritt's Avatar
MadMerritt is on a distinguished road
Default 4.3 feels gutless to drive
Gday all
My 99 LS 4door Blazer has lost its grunt. Car starts,runs & drives well in both 2 & 4wd. Has NO warning lights flashing
on the dash but its gutless under acceleration. I pull plugs out & engine seems to be lean as.
Any advise on where to start checking is greatly appreciated
Old Dec 31, 2018 | 11:23 PM
Could it be the transmission or torque converter?
Old Dec 31, 2018 | 11:53 PM
cleburne red's Avatar
It appears to be running lean? Have you checked fuel pressure?
Old Jan 1, 2019 | 12:10 AM
MadMerritt's Avatar
Trans shifts & downshifts like normal
Not yet as didnt really know where to start lookin. But will check fuel pressure in next day or 2
Cheers
Old Jan 1, 2019 | 02:07 AM
odat's Avatar
Check out the sticky at the top for fuel pressure checking, also check the cat for a partial plugged condition, is the outflow good or does it feel weak ?
Old Jan 1, 2019 | 06:22 PM
MadMerritt's Avatar
Outflow does feel a little weak so ill drop the cat out today & check it
Cheers
Old Feb 1, 2019 | 12:55 PM
go chevy's Avatar
Maybe your fuel injectors are clogged up some??? I would pour a bottle or 2 of SeaFoam fuel injector treatment in your gas tank and see if that helps... It is not expensive and can't hurt even if the problem dosen't go away
Old Feb 1, 2019 | 06:06 PM
odat's Avatar
go chevy
Even tho seafoam, lucas and other fuel additives are great products stay with the recommended dosage or below.
They work well to remove fuel varnish and other contaminates from the fuel system but they are still a super heavy duty detergent/solvent.
Even tho seals, hoses and such are oil/gas resistant over strength/use can and will slowly eat on and break down such parts over time.
Old Feb 2, 2019 | 10:36 AM
go chevy's Avatar
go chevy
Very true indeed! My bad, I meant a 1 time thing lol... I use SeaFoam once a month, 1 bottle in the tank every 4th fill up at the pump
Wannabe
Aug 25, 2011 11:04 PM
gene00000
Apr 23, 2011 06:32 PM
JPRBlazer
16
May 26, 2010 08:12 PM
pug817
Apr 18, 2009 09:45 AM
my93s10
Jun 15, 2008 10:15 PM
