4.3 stuttering
Old Feb 26, 2010 | 12:56 AM
stevelknievel's Avatar
stevelknievel is an unknown quantity at this point
Default 4.3 stuttering
long story short, my truck sat for a week and wouldnt start. i gave it a full tune up and it started but would barely run, replaced the MAF and it runs better but now the only issue im having is when taking off or accelerating it stutters and bogs. once its above 3500 rpm it seems to be fine. any ideas on what could be causing this?
Old Feb 26, 2010 | 08:48 AM
juddkennedy's Avatar
juddkennedy is on a distinguished road
I have been reading some post and I think it is the distributor cap needs to be replaced. Search the post about this issue. good luck
Old Feb 26, 2010 | 10:11 AM
i did the full tune up its brand new
Old Feb 26, 2010 | 11:05 AM
rriddle3's Avatar
Have you cleaned the EGR and checked the throttle position sensor (TPS)?
Old Feb 26, 2010 | 12:03 PM
Sisk's Avatar
You should also define what you have done better. A little more then "full tune up". I would have suggested distributor cap and rotor also as you didn't specify that. I'm assuming you've also done plugs and wires too? Is it throwing any codes?
Old Feb 26, 2010 | 04:14 PM
yes cap rotor plugs and wires it threw a o2 sensor code but its had that forever
lukifer
Nov 11, 2014 06:13 AM
emmietrainor
Aug 10, 2013 01:41 PM
Mikeman84
Jun 13, 2013 06:44 PM
78K5
Apr 18, 2012 03:49 PM
killerelfboy
Feb 27, 2008 06:58 AM
