4.3 vortec fuel pressure port leak
Old Jan 16, 2018 | 09:23 AM
djgold100's Avatar
djgold100 is on a distinguished road
Default 4.3 vortec fuel pressure port leak
My 1994 s10 blazer with the 4.3L code W has a fuel pressure port located on the back of the intake where the fuel line comes in. It appears to be leaking has around the base of the port. Has anyone experienced this and what is required to fix it? There doesn't appear to be any leakage around either the inner or outer fuel line connections.
Old Jan 16, 2018 | 09:41 AM
Rusty Nuts's Avatar
Welcome to the forum. It sounds like your schrader valve is leaking. It's the same kind of valve that's in your tires. I'd stop by the tire shop and have them replace it. You could buy one and the tool to change it for cheap but I bet a tire shop will do it for free so you'll like them and consider them for your next tire purchase.
Old Jan 16, 2018 | 04:03 PM
newguy's Avatar
He said it was leaking around the base. Since its high pressure you may have to replace the line
Old Jan 18, 2018 | 11:15 AM
djgold100's Avatar
Thanks, I'll try that.
camohunter
Mar 2, 2014 09:24 PM
camohunter
Feb 23, 2014 06:08 PM
nineteensixtycaddy
Apr 16, 2010 07:27 AM
rick oshay
Apr 15, 2010 06:29 AM
Taz
Oct 17, 2009 12:21 PM
