4.3L ignition upgrade kits?
Old Apr 19, 2013 | 08:21 PM
gitch93's Avatar
gitch93 is on a distinguished road
Default 4.3L ignition upgrade kits?
just wondering if any ppl have done the ignition upgrade kits on the 4.3. i have cap,rotor,new distributer,plugs,wires and coil. i was wondering if msd ignition digital box or mallory will work on our systems?
Old Apr 19, 2013 | 10:18 PM
Twip's Avatar
i had a buddy do it on a 1st gen, but i dont know how well it worked out AND weather or not he had it hooked up right.....
just sayin
Old Apr 19, 2013 | 10:42 PM
gitch93's Avatar
would be a great mod for the truck to liven it up some more give me the extra power for hauling and offroading
Old Apr 19, 2013 | 10:49 PM
Your 2000 has EDI: The CKP generates a 3X pulse, (accurate to 20K+ RPM) and sends it to the PCM. The PCM calculates ignition timing and sends a pulse to the ignition module, (also accurate to 20K+RPM). The module sends a pulse to the ignition coil to fire it. The OEM coil is capable of 40K+ volts, (secondary ignition only uses ~4K). No need to upgrade, it's already overkill AC Delco plugs, cap & rotor and make sure camshaft retard is within specs. Doesn't get any better!
Old Apr 20, 2013 | 12:50 AM
gitch93's Avatar
good to know thx captain pretty in depth stuff but i learned more today. i run a full ignition system just was wondering if a msd box would help it but ill keep it oem.
Old Feb 22, 2019 | 09:07 PM
TStoddard's Avatar
TStoddard is on a distinguished road
Thanks Captain, good info to know. I burn through caps & rotors every year regardless of what I pay. Really plays with performance & mileage. I'll have to hunt down some AC Delco on Amazon and give that a shot.
Old Feb 23, 2019 | 04:43 PM
Originally Posted by TStoddard
...I burn through caps & rotors every year regardless of what I pay.
Might want to consider having CMP, (camshaft retard) checked, and adjusted if necessary. Spec is zero degrees, (+ or - 2 degrees). If it's out of spec, it will cause premature cap & rotor failure, not to mention affecting performance and fuel mileage.
jatkins3983
May 28, 2024 11:15 PM
monette999
Jun 11, 2015 01:53 PM
gohan69
Engine & Internal
18
Mar 22, 2011 08:12 AM
warlock3055
Mar 16, 2010 05:33 AM
02 Vortech
Engine & Internal
Jul 8, 2005 08:47 AM
