4.3l vortec auto to standard tranny
Old Dec 30, 2021 | 04:06 AM
Lettucehead 306's Avatar
Lettucehead 306 is on a distinguished road
Default 4.3l vortec auto to standard tranny
Hi my 4.3l motor in my 99 blazer is shot and it has an automatic tranmission i need to know if i can put in another 4.3l motor that came out of 2000 s10 5 speed standard? Will tbe transmission have tbe same bolt pattern
Old Dec 30, 2021 | 08:25 AM
Yes, it will work fine. Check to make sure the pilot bearing has been removed, or at least won't interfere with the nub on your torque converter.
Old Dec 30, 2021 | 10:53 PM
Awesome thanks f or ur time and input i feel alot better now because that was brought to my attention after i purchased it already
Old Dec 31, 2021 | 09:40 AM
LesMyer's Avatar
You will need to change oil pans and oil pickup tubes if there is any difference in the oil pan. Other than that you are golden. Oil pan is part of auto trans mounting for certain. Not sure about manual trans bellhousing mounting.
Old Dec 31, 2021 | 07:49 PM
I didn't even think about that. I put a manual transmission in mine, but it wasn't the "normal" one, so I wouldn't know for sure if there are any fitment issues. Hopefully not.
To the OP,
If I were doing the job, I would probably reseal the replacement engine before installing it (oil pan, valve covers, maybe intake manifold and timing cover), whether or not you have to change the oil pan. They're notorious leakers, and it's never going to be any easier to replace the gaskets than when you have it on a stand.
Old Dec 31, 2021 | 11:38 PM
LesMyer's Avatar
To the OP,
Good advice!!
christine_208
Dec 13, 2021 10:53 AM
jirard
Feb 20, 2009 09:58 AM
grovecdn
May 12, 2008 06:45 AM
Shizer
Jul 7, 2007 09:46 PM
BlazedBlazer420
May 29, 2007 05:56 AM
