4l60e no second gear
Old Jul 25, 2015 | 09:26 AM
kraut681's Avatar
kraut681 is on a distinguished road
Default 4l60e no second gear
I have a 94 s10 blazer 4.3 vortec "w" 4l60e tranny. Everything was working fine, then I had a leak of the front tranny seal. Dropped transmission, replaced seal and torque converter, new tranny filter and pan seal. No debris in pan at all. Put back together now wont shift into second gear. Starts fine in 1st and have to let off throttle to shift and goes directly into third. All other gears work fine. TPS is measuring fine. What else can it be?
Old Jul 29, 2015 | 01:14 PM
abig84's Avatar
vehicle speed sensor maybe? does your speedometer work? i have a 93 that i changed transfercases to a manual case and theres no where to plug in the vss and thats how my trans is. stays in first unless i red line it or manually shift it into second
Old Aug 9, 2015 | 05:26 PM
kraut681's Avatar
Yea, the speedometer works.
k5009
Jul 19, 2010 12:34 AM
black4x4blazer
May 23, 2010 02:48 PM
schreckman
Mar 20, 2009 09:27 AM
vetteandblazerman
Mar 8, 2009 01:25 PM
2KBVDA
Oct 30, 2008 03:52 PM
