4l60e transmission problem
Hello! Ive been trying to find the pinout diagrams for the PCM as well as the 4l60e transmission. I have a 4l60e stuck in limp mode with a code of p0758. This 2002 chevy s 10 only has 2.2l only has 81000 miles on it. The transmission was changed because of this same problem,but this 4l60e does the same thing as the original transmission . I very sure its in the wire somewheres..Does anybody have any ideals? Thanks
Check fuse #11 in the instrument panel fuse block. Does the lights work for the gear indicator in the dash? Here is a pin out of the PCM and transmission. #51 yellow/black wire from PCM is ground for solenoid. Good luck.
pselby007@yahoo.com
Dec 1, 2015 09:05 PM
95blazer8620
Oct 19, 2007 01:26 PM
