4l60e transmission problem
Old Nov 27, 2018 | 10:27 PM
Charlesdowell6250's Avatar
Charlesdowell6250 is on a distinguished road
Default 4l60e transmission problem
Hello! Ive been trying to find the pinout diagrams for the PCM as well as the 4l60e transmission. I have a 4l60e stuck in limp mode with a code of p0758. This 2002 chevy s 10 only has 2.2l only has 81000 miles on it. The transmission was changed because of this same problem,but this 4l60e does the same thing as the original transmission . I very sure its in the wire somewheres..Does anybody have any ideals? Thanks
Old Nov 28, 2018 | 05:08 AM
Transman304's Avatar
Check fuse #11 in the instrument panel fuse block. Does the lights work for the gear indicator in the dash? Here is a pin out of the PCM and transmission. #51 yellow/black wire from PCM is ground for solenoid. Good luck.
Old Nov 28, 2018 | 05:32 AM
Default 4l60e
thanks for your help.i will study it and put the info to use.
Old Dec 3, 2018 | 04:43 PM
Thanks for the help. It was my pcm. I put one into my s10 today and my check engine light is off,and my truck shifts great.
Old Dec 3, 2018 | 05:01 PM
Great news! Thanks for the update.
Brad
mtntrekker55
Apr 16, 2021 12:25 PM
pselby007@yahoo.com
Dec 1, 2015 09:05 PM
jlhamm
Nov 2, 2009 06:11 PM
i3lomeh
Feb 27, 2009 12:12 AM
95blazer8620
Oct 19, 2007 01:26 PM
