4x4 diaphram
i have a 99 blazer and when i start the engine the diaphram pulls the cable to lock the front diff without putting it into 4wd. shouldnt it only move once 4wd is engaged? what is causing a constant vaccum on this diaphram what is needed to be replaced to fix this problem?
On the firewall, just about in the center, there is an electro vacuum switch that looks like this:
Unplug the electrical connector and see if it still applies vacuum to the actuator under the battery and pulls the cable.
If that's the case, the switch on the transfer case is stuck and needs replacement. It's located on the driver side, inboard and slightly above the front output shaft. This is what the switch looks like: Dorman Help! 49315 - TRANSFER CASE SWITCH | O'Reilly Auto Parts
And this is where it's located:
You can use a 7/8" deep socket on a 3/8" drive ratchet to replace it. 15 minute job.
AllenValk66
Dec 7, 2010 12:08 PM
razman
Feb 22, 2009 01:57 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
