4x4 help please!
Old Mar 20, 2017 | 06:33 PM
  #31
broark2017's Avatar
broark2017 is on a distinguished road
Originally Posted by Lesmyer
To OP. If you can use your EOBD Facile to communicate in a proper terminal mode, what you enter to check, interpret, and clear codes is at the end of this thread.
https://blazerforum.com/forum/2nd-ge...-blazer-89044/
Very Very detailed write up there !!! Thanks for sharing
Old Mar 20, 2017 | 10:11 PM
  #32
LesMyer's Avatar
You're welcome, but I didn't write it - only collected it and used it when diagnosing mine.
Old Mar 22, 2017 | 04:42 PM
  #33
broark2017's Avatar
Encoder changed ... It was split apart on the top and bottom and cracked around the bottom bolt.. So anyone having similar issues with 4wd take a flashlight and look closely at the encoder motor. I never saw that it was split apart or cracked until I took it off . But on the positive side 4wd is up and running !! Woohoo ! Now that damn rattle is still there ..now in 4hi or 2 hi. Is there anything inside the passenger fender that could come loose ?
Old Mar 22, 2017 | 04:53 PM
  #34
LesMyer's Avatar
Congrats, thanks for letting us know.
Old Mar 22, 2017 | 04:56 PM
  #35
broark2017's Avatar
Thanks for all the info and opinions from everyone .. Great forum and I will still be looking around daily !
Old Mar 22, 2017 | 08:55 PM
  #36
Strangerock's Avatar
Strangerock is on a distinguished road
How about a shock that came loose ?....or the notorious hood hinge bolt that comes loose and sounds like something clunking around the dash speaker area?
Old Mar 22, 2017 | 09:05 PM
  #37
broark2017's Avatar
I've done fixed the hood .. It's not really a clunking ..the noise is hard to describe other than a rattle ..no difference over bumps,when turning or braking . It does it mostly between 35 and 45 and if I keep it there it stays..speed up or slow down ..gone. Everything in the front end is new and I took it for a ride after replacing each part .. no difference.. so it's really aggravating the heck out of me . At first I thought it was something that the wind coming through the engine compartment was making something rattle but that would get worse with speed I would think. Then I thought cat ..But It makes no noise sitting and revving the engine or when I tap the exhaust ..I'm sure I will find it eventually and think Duh.. lol but until then radio up and noise is gone ! Ha ha
Old Mar 22, 2017 | 09:11 PM
  #38
broark2017's Avatar
This forum and hands on with this beast have really taught me a lot about these trucks.. I've always been a 80's Monte Carlo person ( I could tear one them apart and put it back together with my eyes closed lol ) but I wanted a change of pace .. 8 of them was enough . Well for a while anyway.
Old Mar 22, 2017 | 09:28 PM
  #39
broark2017's Avatar
Default The busted encoder
This is why the 4x4 did not work.
Attached Thumbnails 4x4 help please!-encoder-1.jpg   4x4 help please!-encoder-2.jpg   4x4 help please!-encoder-3.jpg
opposedforces
Sep 1, 2011 02:59 PM
mikejoann
Jan 4, 2010 10:23 AM
rogggg1020
Nov 11, 2008 08:05 AM
scoot
Jan 1, 2007 04:48 AM
1996blazer
Dec 6, 2006 09:34 PM
