700R4 fluid capacity?
Old 10-31-2007 | 07:07 PM
corr33's Avatar
corr33 is an unknown quantity at this point
Default 700R4 fluid capacity?
Does someone know the fluid capacity for the 700R4 tranny off the top of thier head? (approximate is fine)
Old 10-31-2007 | 07:59 PM
Default RE: 700R4 fluid capacity?
Dry capacity with a shallow pan should be around 11qts. Deep pan will be around 12 qts. If you have an addon cooler, it could be close to 13qts.
If you are doing a pan drop & filter change, take off 5-6qts from those values for what is held in the torque converter and internals of the transmission.
If you are doing a DIY flush by disconnecting the stock cooler line and running the engine to pump out the old fluid and filling back in through the dipstick tube, then you will want to have double the capacity on hand due to mixing in the pan. If you do a pan drop and filter change first, then you only need to have 1.5x the fluid on hand.
bertrenolds
02-17-2011 05:05 PM
irondooks88
06-21-2010 04:58 AM
republic
10-12-2009 05:58 PM
TAZ454
02-01-2008 03:57 AM
KennyJonson
12-26-2006 07:09 AM
