93 4.3 vin z hard start, missing, dieseling...HELP
Old Jan 11, 2014 | 03:11 AM
dbarrowjr's Avatar
dbarrowjr is on a distinguished road
Default 93 4.3 vin z hard start, missing, dieseling...HELP
ok. i need some pro help. i have a 93 4.3 vin z. its just recently, like literally overnight, started screwing up. it turns over for a few seconds then finally starts, it misses at idle and all throughout the driving range from acceleration to slowing down, and it diesels or "runs-on" for about 3 seconds and finally dies down with a finishing knock after shutting off the key. i put a new fuel pump, fuel filter, fuel pressure regulator, plugs, wires, dist cap and rotor button and checked the timing and the gears are lined up to the T. i even put a new timing chain on it bc it had a tiny bit of slop in it but i still have the same problem as before. so...any advice?
Old Jan 13, 2014 | 09:52 AM
jerry n's Avatar
jerry n is on a distinguished road
have you had the codes checked? try unplugging the throttle position sensor an see if the idle gets any better. I had the slow starting an the rough idle. changed the tps and its been fine for a few days now. good luck.
Old Jan 14, 2014 | 05:53 AM
dbarrowjr's Avatar
yes that has been changed. i got it all put back together tonigh but tried to crank it and the battery was dead so i had so i have to let it charge overnight. so, we will see what happens after a night on the charger. ill post an update and see what i have found out
93S10TahoeLT
Apr 5, 2013 06:59 PM
sedatedbylife
Engine & Internal
Feb 27, 2010 10:54 AM
SlydinClyde
Oct 18, 2009 08:14 PM
BradensCreed
Aug 25, 2007 03:22 PM
BlazerSS
Engine & Internal
Apr 21, 2007 03:44 PM
