93 s10 trans leak
Old Nov 17, 2009 | 10:24 PM
jeffyb0y69's Avatar
jeffyb0y69 is an unknown quantity at this point
Default 93 s10 trans leak
i have a tranny leak somewhere under the passenger side. i dont know how bad it is, but there was fluid that was dripping from what looks like a black round thing up underneath the passenger side. i dont know much about cars or id be more specific. i cant tell if it is leaking from the part, ot if there are hoses on top of that part that need to be fixed. anmy suggestions? i can take pics if u can help me.
Old Nov 17, 2009 | 10:29 PM
The transmission cooler lines run along the passenger side. The location of the leak depends on where and what is leaking. If it is near the center of the transmission, it could be a leak at the fittings where the lines go in/out of the transmission. If it is near the center of the engine, your lines have likely cracked or worn through. If it is near the radiator, it is likely leaking from the fittings into the radiator.
Old Nov 19, 2009 | 10:38 PM
jeffyb0y69's Avatar
when i took off the heat shield the fluid was orangish in color. i know it is tranny fluid. there was a plastic semi circular clip that was on the insodse of the heat shield when i took it down. i dont know if that means anything. but, can i just feel if the fittings are leaking....and if i can can i just tighten them? or do i have to replace the whole thing? the fluid was on the bolts and drips when i drive it i see a small trail when i drive. i have to check the radiator fittings again, it did this only after i replaced it. It is also hard to pull the shifter out of park and put it back in. what is part of that problem?
Old Nov 20, 2009 | 06:00 AM
Until you find the precise location of the leak, you won't know what you have to replace. A mechanics mirror will help you locate the leak.
ksunday1
Nov 5, 2013 02:22 AM
m.sterner
Nov 29, 2009 10:34 PM
86blazeder
Feb 24, 2009 07:33 PM
luthers97blazer
Nov 10, 2008 01:27 PM
rob1621
Feb 29, 2008 08:15 PM
