93 s10 wont start please help
Old Jan 25, 2014 | 03:28 PM
93 nightmare's Avatar
93 nightmare is on a distinguished road
Default 93 s10 wont start please help
Ok I have a 93 4.3 vortec that will not turn over... there is no fuel presser at the engine bleeder valve.. and the fuel pump does not make any noise anymore... so I checked the wire harness at the fuel pump and there is power when you turn the key... so I changed the relay just because dropping the tank isn't fun and nothing changed.. so I changed the fuelpump and still no change... so still I have no fuel presser what so ever and the new pump does not make any noise... NOTE.. the spiderinjectors are about a year old and fuel filter is 2 years old.. and the truck was running fine all day and an hour later went to go somewhere and now this... PLEASE HELP>>> thank you
Old Jan 26, 2014 | 01:05 AM
abig84's Avatar
make sure it has a ground too. some of the older vehicles had a ground wire that would run off the top of the tank and ground to the frame or body.
Old Jan 26, 2014 | 02:17 AM
yeah saw that when I removed the old fuel pump and just checked to make sure that I reattached it
welderman85
Jan 10, 2014 10:06 PM
1992S10blazer4.3
Jan 29, 2010 08:35 PM
jimmy979
Oct 11, 2009 06:28 PM
00blazerLS
17
Jul 6, 2008 07:44 PM
scottyk
Mar 14, 2007 09:54 PM
