95 and 98 tranny
Old Apr 29, 2008 | 12:07 AM
waldon005's Avatar
waldon005 is an unknown quantity at this point
Default 95 and 98 tranny
Does anyone know if a 4l60e out of a 98 blazer will work in a 95 blazer? Both four wheel drive four doors?
Old Apr 29, 2008 | 06:14 AM
Default RE: 95 and 98 tranny
No. The '98 will have a 2 piece main case which is shorter in length (23.38" for the early 4L60E and 21.9" for the late 4L60E). Also, the bolt pattern for the transfer case (or tail housing if 2wd) changed between the early 4L60E (4 bolt (square) pattern) and the late 4L60E (6 bolt (hex) pattern).
Old Apr 29, 2008 | 01:19 PM
blazin97's Avatar
blazin97 is on a distinguished road
dang swartlkkyou amaze me atleast one a week with how informed you are about Blazers. I give you mad props.
Old May 5, 2008 | 03:28 AM
waldon005's Avatar
so there is no possible way that the tranny out of the 98 blazer will work in my 95 blazer?
Old May 5, 2008 | 06:17 AM
Transfercase, front and rear driveshafts, and transmission and hope that everything works the same with the transfer case (I'm betting not). It isn't a simple plug-n-play...
Now, if there is a difference in the transfer case dimensions from mounting flange to both driveshaft mounts (tailshaft extension in the rear and mounting flange in the front) that equals the difference in length between the two transmissions, you would not need the driveshafts.
If the transfercases were to both be the 2 speed selectable (i.e. non-automatic), then you may be able to use your transfercase encoder motor, but I don't know that as fact. I don't have my references with me at work so I can't check the specific transfercase models used in these two years.
In the end, anything is possible, just depends on how much work you want to put into it. I would look for another single piece main case transmission from a 4wd...
Old May 6, 2008 | 03:52 AM
waldon005's Avatar
Well good news. I did have to use the spacer between the tranny and transfer from the 98 blazer other than that everything works perfectly!
Old May 6, 2008 | 06:38 AM
So you used the spacer from the '98 to bolt up to your transfer case. Good deal! How did you cover up the front, lower portion of the bellhousing?
Old May 7, 2008 | 10:26 PM
waldon005's Avatar
i went back to the guy i got the tranny from and got the shield and put it on
ski.dive
Feb 7, 2014 05:18 AM
hardyboy
Mar 23, 2011 08:04 PM
88s10Blazer
Nov 29, 2006 02:56 AM
Jetfixer
Jul 11, 2006 05:02 AM
sting_da_man
Mar 13, 2006 12:48 PM
