95 chevy blown motor
Old Mar 24, 2013 | 02:43 PM
Mike Mahaffey's Avatar
Mike Mahaffey is on a distinguished road
Default 95 chevy blown motor
95 chevy blown motor, radiator busted and blew the headgasket, wanting to replace the headgasket or the motor, what issues would i be looking at if i replace the head? what bout the motor? only motor I've found is from a 95 2wd truck.
Old Mar 24, 2013 | 05:42 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Since the engine you found is a truck motor Im assuming its tbi?if so you can swap your cpi manifold.
As for the blow head gasket drain the oil imediately.Remove the intake manifold.Then remove the head and have it checked for cracks before replacing it with a new head gasket.Also use new head bolts.You can get a set of felpro bolts they are just as good as arp and alot cheaper.
Old Mar 24, 2013 | 06:20 PM
Default head gasket
well i'm not going to be able to do it myself, I called a local shop and they said it would cost me around $1000 for the repairs, should I keep calling around, or does this sounds legit?
Old Mar 25, 2013 | 09:55 AM
I understand maybe your not mechanicaly inclined to do the work?You didnt mention that in your post.I assuming that 1g is to remove the head,check it for cracks and replace the head gasket?Shop around $1000 sound rediculous.
Old Mar 25, 2013 | 09:56 AM
If the $1000 is to change the engine thats about the going price so Im not sure what option your planning but can you specify?Thanks.
Old Mar 25, 2013 | 05:06 PM
Default blown headgasket
I'm looking at both options at the moment, that being said I was looking towards replacing the gasket until I was told that once water gets into the oil it can lock up the bearings and cause the rings to start burning oil. So now i'm looking more towards the motor, the most recent motor I found the guy wants like 500 bucks for it and said he'd install it for another 500.
Old Mar 26, 2013 | 06:44 AM
Thats why I mnetioned drain the oil imeddiately on the old engine.It may be or not too late depends on long it was driven once you noticed the problem.
Anyways $500 the engine and another 5 bones for install that isnt bad and its in the range for having this kinda of work done or cheaper.If I did this job for someone definately $500 is what i would charge so go for it.Does the truck engine have tbi or cpi?If it has tbi you will have to swapped the top ends.
Old Mar 26, 2013 | 07:29 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
also if the replacement is a tbi engine it will have an extremely wimpy cam compared to the cpi in your 95. It should run fine but expect power loss.
limited edition 1
Jan 27, 2023 11:07 AM
WhiteNoiz
Jul 31, 2009 10:55 PM
Shabba
Apr 4, 2009 02:50 AM
BlazerRomone
Jul 16, 2007 06:54 AM
GMdesigner
Jul 12, 2007 12:23 AM
