95 chevy blown motor
95 chevy blown motor, radiator busted and blew the headgasket, wanting to replace the headgasket or the motor, what issues would i be looking at if i replace the head? what bout the motor? only motor I've found is from a 95 2wd truck.
Since the engine you found is a truck motor Im assuming its tbi?if so you can swap your cpi manifold.
As for the blow head gasket drain the oil imediately.Remove the intake manifold.Then remove the head and have it checked for cracks before replacing it with a new head gasket.Also use new head bolts.You can get a set of felpro bolts they are just as good as arp and alot cheaper.
I understand maybe your not mechanicaly inclined to do the work?You didnt mention that in your post.I assuming that 1g is to remove the head,check it for cracks and replace the head gasket?Shop around $1000 sound rediculous.
I'm looking at both options at the moment, that being said I was looking towards replacing the gasket until I was told that once water gets into the oil it can lock up the bearings and cause the rings to start burning oil. So now i'm looking more towards the motor, the most recent motor I found the guy wants like 500 bucks for it and said he'd install it for another 500.
Anyways $500 the engine and another 5 bones for install that isnt bad and its in the range for having this kinda of work done or cheaper.If I did this job for someone definately $500 is what i would charge so go for it.Does the truck engine have tbi or cpi?If it has tbi you will have to swapped the top ends.
limited edition 1
Jan 27, 2023 11:07 AM
