95 s10 blazer 4x4 Tranny slipping
Old Mar 15, 2010 | 10:10 AM
speedfreakz's Avatar
speedfreakz is on a distinguished road
Default 95 s10 blazer 4x4 Tranny slipping
I have a 95 S10 Blazer 4x4 auto that just started slipping in drive and overdrive. The fluid is full and doesn't smell burnt. Im going to do a fluid and filter change today but is there anything else that may cause this i really can't afford to replace the whole transmission?
Also 1st and 2nd seem to drive fine when i manual put it in those gears.
Old Mar 15, 2010 | 10:21 AM
A slipping 4th gear can be caused by a missing or incorrectly located check ball. Sometimes this can be caused by a check ball that wears through the separator plate in the transmission.
Both conditions could be caused by a missing or blown out orifice cup plug in the 2-4 servo assembly.
Either problems *should* be able to be corrected without a rebuild.
Old Mar 15, 2010 | 10:29 AM
Default Question?
Do you happen to have a how to guide to do this. Is there a repair kit for this issue? I can do almost anything if i have a how to in my hand. Any info would be hopeful. Thanks
Old Mar 15, 2010 | 10:46 AM
Have you ever opened up an automatic transmission before? These items are located on or near the valve body and can be accessed with a pan drop. However, there is more stuff in there that you can screw up in the process of getting to these areas.
Old Mar 15, 2010 | 10:56 AM
I have repaired minor issues with auto transmisions. I will check it out thanks for the info.
Old Mar 15, 2010 | 09:01 PM
So i changed the filter and fluid with no change at all. I did pull the trouble codes and i got a code for
solenoid a solenoid b and p1843 code about transmission. Is this transmission shot or fixable?
Old Apr 2, 2010 | 09:50 AM
Unhappy Replaced Transmission and torgue converter but still the same issue.
I replaced the transmission with one from a working s10 from my local yard. He warrantied it and everything but i do not want to rip that thing out again. could there be a wiring problem that makes D and OD slip but not 1 or 2?
underground260
Feb 28, 2012 04:25 PM
kwilliams
Apr 2, 2010 10:42 PM
painter203
Jan 21, 2009 07:46 PM
carlo
Aug 1, 2007 12:45 AM
Blahman20
Jun 14, 2007 11:14 PM
