95 trans swap
Old Aug 10, 2020 | 08:42 AM
Maudh Alraggad's Avatar
Maudh Alraggad is on a distinguished road
Default 95 trans swap
Getting ready to swap trannys in my 95 blazers, can anyone tell me all the gaskets and/or o-rings I will need to go ahead and order
Old Aug 11, 2020 | 09:22 AM
dviles's Avatar
dviles is on a distinguished road
You don't NEED any, but you should seriously consider changing your rear crankshaft seal while you have the transmission pulled.
Old Aug 11, 2020 | 04:08 PM
daveca's Avatar
Are there O rings on the tranny cooler on the radiator? Those aren't affected by a trans pull but just a suggestion if there are and lines are removed.
and absolutely...change rear main seal. Cheap part hard to get to with trans in.
Old Aug 15, 2020 | 10:11 AM
What about the trans pan? No gasket?
Old Aug 15, 2020 | 11:17 AM
daveca's Avatar
Yes on the pan. The fluid and filter change interval on the 4L60E according to GMs factory manual was IIRC 40K miles so if the replacement trans had nit been serviced, it would be good to change the filter and pan gasket, and clean the pan.
Also check the U joints while the driveshafts are out. Move them thru their range of motion and feel for binding or excess play.
Old Aug 21, 2020 | 08:06 AM
a gasket between the transmission and transfer case? If so what’s it called?
Old Aug 21, 2020 | 11:49 AM
I would also replace the front pump seal on the transmission while you have it out.
Old Aug 21, 2020 | 11:53 AM
Transman304's Avatar
Transfer case gasket. Should also change the input seal on the transfer case
SKF 19255 seal Felpro #72769 gasket
Brad
Maudh Alraggad
Aug 1, 2020 08:02 AM
Daj1975
Dec 10, 2019 07:28 PM
blackmamba4x4
Jun 28, 2017 10:57 PM
ksunday1
Nov 5, 2013 02:22 AM
im2ys4it
Mar 31, 2008 08:39 PM
