95 trans swap
Old Oct 1, 2018 | 09:18 AM
Dkarll88's Avatar
Dkarll88 is on a distinguished road
Default 95 trans swap
So i just bought a 95 blazer with burnt up 3-4 clutches thinking id just get a junk yard unit and slap it in..well i didnt realize the 95 was a one off year and now im looking a 950+ for a rebuild. Is there anything i could do to swap in a newer year? Swap plugs on harness? Also i have a 4 bolt dust cover and im only finding 95's with a 6 bolt dust cover. What is the difference? Thanks for any help
Old Oct 1, 2018 | 02:08 PM
Transman304's Avatar
The 4 bolt dust cover is for 2wd vehicle. The 6 bolt cover is for 4wd. Is your blazer 2wd? If not it has been changed at some point. The steps required to make a newer unit work is very costly and time consuming unless you are quite familiar with transmissions. Good luck.
Old Oct 1, 2018 | 02:22 PM
Dkarll88's Avatar
Well this one if forsure 4x4 and has 4 bolts. Will a 6 bolt fit right in and be fine then?
Old Oct 1, 2018 | 02:25 PM
Dkarll88's Avatar
is there a way i could measure driveshaft length to tell whats going on? I just pulled the transfer case last night
Old Oct 1, 2018 | 03:14 PM
There is no dimension difference at all in transmissions You can use your 4 bolt cover on a 6 bolt case just have to drill cover for larger diameter bolts.
Old Oct 1, 2018 | 03:17 PM
Dkarll88's Avatar
wow thats a game changer. Ive had people telling me a 6 bolt wouldnt work.
Old Oct 1, 2018 | 03:39 PM
95 trans swap-78a1e9df-d332-47c0-bd2b-6d3d37d5e764.png95 trans swap-985855e2-a37f-40c9-8619-540d5a31273e.png
these are the 2 covers. Which one is on your transmission?
Old Oct 1, 2018 | 05:26 PM
Dkarll88's Avatar
Attachment 36747Attachment 36748
It doesnt look to match either one
Old Oct 1, 2018 | 06:19 PM
Dkarll88's Avatar
w
it is forsure more similar to the bottom one with the spots for the support rods.
Old Oct 1, 2018 | 10:05 PM
You have a 6 bolt transmission. Be sure to flush the cooler and cooler lines very good before installing other transmission.
