96 Blazer 4x4 LT, no 2nd gear-AT
Old Oct 18, 2015 | 06:59 PM
taekwondad40's Avatar
taekwondad40 is on a distinguished road
Unhappy 96 Blazer 4x4 LT, no 2nd gear-AT
I was on my way to work and only got about a half block from my driveway and CLUNK when my Blazer tried to shift into 2nd gear....but lost forward motion instead. Reverse still functions, as do 1st and Park. The clunk was so intense, I thought it felt like the front drive shaft had dropped from the front end, and caught the street then banged up against the under-side. Tried a slow test drive in the parking lot across the street later. Same symptom. Fluid checks out normal. On another thread here, I read something about a VSS on the top/rear/driver-side of the transfer-case as a likely fix. However, I haven't seen anyone else with the same exact issue as mine. I guess there's another reason I named it MONSTERDAD when I bought it.
Old Oct 18, 2015 | 07:53 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Broken "drive shell"? Sounds like rebuild time.
Old Oct 20, 2015 | 10:59 PM
slimsummers's Avatar
slimsummers is on a distinguished road
Yep, overhaul time.
badge4279
Sep 26, 2010 06:28 PM
stepjl
Sep 25, 2010 12:17 AM
75 blazer
Aug 13, 2010 06:36 AM
OrionSS3
Nov 4, 2009 01:43 PM
BOTTLEDZ28
Dec 3, 2007 08:18 AM
