97 blazer 4x4 will not shift in any gear
Old Aug 23, 2008 | 12:34 AM
bethrad's Avatar
bethrad is an unknown quantity at this point
Default 97 blazer 4x4 will not shift in any gear
i have a 97 4x4 blazer that will not shift into any gear. if the rear tires are off the ground it shifts fine. i just had the vss changed a week before the transmission stopped pulling when on the ground. its weird that it shifts when the rear is in the air but as soon as you set it on the ground it wont go anywhere. the fluid and filter are fine. it whined a little bit then on the way home the ses light came on then it quit pulling. help what could my problem be.[:@]
Old Aug 23, 2008 | 09:09 AM
Default RE: 97 blazer 4x4 will not shift in any gear
I will assume that you have checked and verified that the fluid level is up to the appropriate level. Sounds like the transmission is toast. I am willing to bet that when the wheels are up in the air, the motion you see is due to the friction inside the transmission and that the transmission is not really holding the gears properly.
Old Aug 25, 2008 | 03:26 PM
bethrad's Avatar
Fluids are fine. I have been told by several tranny shops that its the front pump. i am so ready to get rid of the blazer for whatever i can get for it. its been a pain in the butt.
Old Aug 28, 2008 | 08:11 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
what are you asking for it? if you sell it of course... the tranny will run you 1500 - 3000 dollars... junk yard 400 maybe...
Old Aug 28, 2008 | 10:34 PM
bethrad's Avatar
i have to have at least $1700 for it. everything else is in excellent condition. the tranny is gonna cost me $950 plus tax to fix.
Old Aug 28, 2008 | 10:37 PM
bethrad's Avatar
thats for a total rebuild with 6 month/6000 mile warranty. i think thats a pretty good price for having it fixed.if i dont get it fixed it i will sell it for $1700. if i get it fixed i will ask $2900.
ssmith0386
Oct 19, 2014 12:47 PM
gvsu141
Feb 10, 2014 08:15 PM
jon602
Aug 23, 2011 07:22 AM
Amish3006
Jul 27, 2009 05:44 AM
2KBVDA
Oct 30, 2008 03:52 PM
