97 Blazer automatic trans electrical issue
Old Jun 27, 2011 | 11:53 AM
SA10A10's Avatar
SA10A10 is on a distinguished road
Question 97 Blazer automatic trans electrical issue
Okay well I have been having issues with my tranny after truck warms up. Once it's warm I basically only have 2nd and 3rd gears with no downshift unless I physically drop it with the shifter. Had the trouble codes read and they showed the 1-2 and the 2-3 solenoids were bad along with a vacuum issue I replaced all vac lines and both solenoids; but truck still has same shifting issues. My question is can someone give me some trouble shooting tips so I can see if these solenoids are even getting a signal??? Or if anyone has any other advice for me it would be greatly appreciated.
Old Jun 27, 2011 | 12:03 PM
Sounds like you have a wiring problem in the pan. You could try doing a continuity test from the solenoid connector back to the PCM connector to see if moving the pan wiring alters the readings any.
Attached Thumbnails 97 Blazer automatic trans electrical issue-97_eng_sch.jpg
Old Jun 27, 2011 | 01:08 PM
SA10A10's Avatar
Okay so I take it these wires do run from the trans straight to the PCM? Thanks for the response and do you have a larger version of the wiring diagram as even after saving it and zooming in I can't read the text on it. Thanks again
Old Jun 27, 2011 | 09:45 PM
Should be nearly identical to this one from a '96. I don't have the one I posted above anymore:
comandoed
Dec 26, 2013 07:32 PM
bobf
Jul 21, 2012 01:03 PM
cory.kiel
Jun 17, 2011 11:41 PM
pc_marshal
Aug 25, 2007 06:55 PM
BigGreenMonster
Aug 24, 2006 01:32 AM
