97 Blazer cranks but won"t start
Old Oct 19, 2008 | 04:38 PM
jdbrown66's Avatar
jdbrown66 is an unknown quantity at this point
Default 97 Blazer cranks but won"t start
I have a 97 blazer with a 4.3 vortec engine. The blazer died while driving down the road, and had to be towed home. I have replaced the ignition module, and had the coil checked. The coil is fine and has spark. The fuel pressure measures 50psi the first time the ignition switch is turned on then goess to 54psi the second time. These readings are pretty consistant as I test them over again. What is the proper fuel pressure for a vortec with MFI? This truck has 160k miles on it with the original fuel pump still installed. I had problems recently with the gas gauge not working also. I also installed a new battery recently. Does this sound like a fuel pump problem, I am leaning towards this, however I would like to know the proper pressures required to make the motor start and run. I have had it running a couple of times for a few seconds then it always dies out. Please help!!
Old Oct 19, 2008 | 04:48 PM
Default RE: 97 Blazer cranks but won"t start
For proper pressures, check the DIY section.
Old Nov 19, 2008 | 03:57 PM
CashMoney402's Avatar
CashMoney402 is an unknown quantity at this point
Fuel pump for sure i had to replace it twice within 3000 miles
Rhodes19
48
Feb 15, 2013 09:46 PM
bsbob
Jul 22, 2011 12:48 PM
triplethreat
May 17, 2011 08:28 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
sindy1232
Jul 25, 2008 11:59 AM
