97 Blazer Idle Issues (Or So It Seems...)
Old 10-11-2012, 02:47 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
You should see improvement after replacing the IAC.I took mine out and cleaned it and seen very little improvement till I replaced with a new unit.Im sure a tuneup will help also.I dont why hardly anyone mentions this when they are diccussing solutions for an engine thats running poorly,Get a can of seafoam and run it through you gas tank.Also take another can and run it through the power brake booster line going into the engine.This stuff works miracles and removes alot of built carbon in an engine with high miles.
Old 10-11-2012, 02:57 PM
50lb_cat's Avatar
I would start off with a tune up. Have you checked your dizzy cap and rotor for signs of arching? I would suspect those to be the issue.
I don't like k&n simply because of the oil. If it gets over oiled it will mess up the MAF and even if it doesn't get over oiled you will constantly be cleaning the MAF. I like the AEM dryflow, no oil, great flow. But if your just tryin to keep her going, I would spend the money else where, IMO.
Old 10-12-2012, 11:20 AM
Now I know why I see so many of those K&n cold air systems forsale used.Our criagslist is full of them.I had no idea they had to be oiled.
Old 11-12-2012, 09:09 PM
dsmith225's Avatar
dsmith225 is on a distinguished road
Well, it's been a while since I have had a chance to update this thread. Figured out a few things about the truck. We did the spark plugs and wires on it, turns out I was missing the 6th spark plug completely. And the wire had a clean cut coming off the cap. After changing out the plugs and running new wires, it runs alot better, not to mention my milege has gone back up.
The next project to fix the ever so seeming mounting list of to-do's is cap & rotor. Possibly a dizzy replacement, not entirely sure yet.
We did run a code reader on it and got a few codes spit out at us. They were for the following..
1. MAF sensor (but, I already knew that one was a given...)
2. Camshaft Position Sensor
3. O2 Sensor
Those three are the next things to get fixed on the truck. Other than that it's been running pretty great actually. I am actually kind of hoping to get some real snow this winter in MN so I can put it in 4wheel and have a little fun with it.
I would like to thank everybody for the thoughts and posts trying to figure the issues out. Ya'll are great!.
-dsmith225
ussexplorer
05-22-2011 09:09 PM
apross44
06-18-2010 08:47 PM
jettmech2002
09-26-2009 11:59 AM
1997liftedblazer
22
05-22-2009 08:40 AM
bucknblazer
04-07-2008 11:56 AM
Quick Reply: 97 Blazer Idle Issues (Or So It Seems...)
