97 Blazer oil cooler leak at radiator
Old Feb 14, 2015 | 02:52 PM
Damato's Avatar
Damato is on a distinguished road
Default 97 Blazer oil cooler leak at radiator
I am new to forum and have a problem hope you can help me with. I had a rebuilt 4.3 installed in my 97 Blazer. The mechanic also put in new radiator. I have had several leaks from bottom oil cooler line in radiator. We have changed the radiator fittings twice, new Doorman cooler line hose and it has started to leak again. Thinking about removing the oil cooler and putting oil filter directly on engine. There is less then 2000 miles on engine change. Could use your help and ideas. Thanks
Old Feb 14, 2015 | 02:59 PM
Welcome to the forum!
Did you replace/install the O rings in the oil cooler fittings on the radiator? Without them, it will leak
Old Feb 14, 2015 | 03:06 PM
Damato's Avatar
Yes, the radiator fittings were new
Old Feb 14, 2015 | 03:10 PM
I understand the fittings were new, but do they have the O rings inside?
Old Feb 14, 2015 | 03:18 PM
Damato's Avatar
I assume the mechanic checked them. The top one never leaks, it is just the bottom one.
Old Feb 14, 2015 | 03:28 PM
That might be the problem Can't assume anything.
You'll need to remove the fittings to see if the O rings are in them... kinda tough to see unless you know what you're looking for.
New radiators usually come with the fittings, and some of the fittings come with the O rings, but not all. No O ring, it will leak, guaranteed. Here is a kit that has all of the seals: Dorman - Help Oil Cooler Line Gasket Assortment 66201: Advance Auto Parts
SoullessNihilist
Jul 7, 2014 08:05 PM
MWS1994
May 12, 2014 03:26 AM
Impact
Jul 19, 2013 09:42 AM
NYC86ZC
Dec 12, 2010 08:21 AM
Jetfixer
Jul 11, 2006 05:02 AM
